Hi guys, finally got round to posting.
I have a long term central heating problem. We moved here about 11 yrs ago, and all was ok for a few years. (It looks like a DIY heating system) Then problems started to raise their heads....noisy vibrating pump, radiators not getting very hot etc. So after a lot of headscratching and asking around, I changed the pump.(the water was black!) Old pump was a four speed, new one is three speed, (Grunfoss).
All was ok for about 18 months after that, then the same thing began to happen. So I bought a new pump, this time a DAB, ( I couldn't believe only 12 month's warranty on a pump!) Again all was ok......for another 18 months or so, and now , here we go again. Radiators downstairs not getting hot for ages, and non getting anywhere near too hot to touch.
The water in the system is very clean looking. I put a cleaner in which seemed to slightly improve matters, but nothing like what it should be.
Could the pump have gone down again?
I checked the last pump I fitted, and, to be honest, there doesn't seem a lot wrong with it. There is no play in the shaft, either way, axially, or radially. All I can see is that the impeller is coated with what looks like a black graphity substance, which I understand is probably sludge.
But if there's sludge in the system, why is the water clear?
I have an engineering background, and a good grasp of the principles of the central heating system, but I'm no plumber. Any help would be greatly appreciated.
And if you want any more details, or have any questions, I'll be glad to answer anything.....thankyou.
