Potteron Profile 80NG
9 Sep 2021
Hi
I have a Potteron Profile gas boiler and the boiler flames up for each mode heating and water.
The heating mode works, but not the hot water mode (stone cold).
Any ideas what this could be? I gather it could be Thermostat, 3 port vale or something else?
One thing to note is that the immersion heats water as expected. Obviously want to keep this switched off.
Thanks a lot in advance.
If you have a 3 port mid position valve, then yes a likely failure, stuck in mid position probably.
Thanks for the reply. Is this a replacement then or can it be repaired?
It depends on brand and type/age - some can be repaired with a kit, some you can just swap the power head (actuator), but it can also depend if the valve itself is stuck, eg the spindle can’t be moved enough.
Its a Honeywell. I will probably just replace it.
Should be no more than an hour?
Oh by the way there was good voltage from the 3 port valve. Could it still show voltage but be faulty e.g. stuck as you mentioned?
Yes it can show voltage, and depending where you’re testing for voltage, might be permanent, and yes can still fail. If it’s got a dimple on the metal cover, then afaik, you can just replace the power head.
