Can anyone help? Just moved into a new flat with the above boiler installed. The central heating works fine when switched to ON on the digital display but it is not responding to the timer. On the first day we moved in, we also had the hot water set to ON on the digital display. When we turned any of the hot taps on, the water only came out in a tiny trickle (the water itself was hot). This lasted for a few days. Then we reset both the hot water and the central heating to TIMED. The c/h didn't work, but we had plenty of hot water. Went to turn the heating on to ON last night as we were cold, and now the hot water has disappeared again! Are we doing something wrong with the settings? Or is it likely to be a problem with the boiler or pipework? Be great if someone could suggest what we might be doing wrong...
Many thanks in advance.
Liz
Liz
