Potterton combi HE Plus 28 boiler
Status
Not open for further replies.
4 Dec 2015
I have a problem with my Potterton combi HE Plus 28 boiler. We noticed a very bad leak coming from the boiler. When taking off the front cover, I noticed the leak was coming from the flexi hose which is connected to the condensate trap (the hose connects to the trap one end and goes up into the boiler, hope this makes sense). On a closer inspection, the hose has a split in the middle. Can anyone advise a cheap solution as I don't have the funds to call out an engineer.
That hose is technically part of the flue. So it will be leaking flue gasses as well as condensate. Put the cover back on turn the boiler off and don't use it until you have got an engineer to replace the hose. Sorry I can't give you better news, but this is certainly not a repair you can carry out yourself. Shouldnt be a very expensive repair though.
Status
