potterton netaheat problem
4 Jul 2011
Surrey
hi guys,i cant get hot water only from my boiler,i have to have the CH on aswell to get hot water,there is 2, 2 port valves upstairs,both the little levers have compression when u pull them across,but when the CH and HW is on the lever on the HW is floppy,ive changed the HW valve and motorised valve inside a couple of times in the last few years,fixs it then goes the same.any ideas?.
also.i have turned all the rads off,so for me to get hot water I need to run the CH aswell,now british gas have told me my gas bill is going from £50 pm to £130 pm,is this anything to do with this as they say I'm using more than expected.
should I have the gas of completely during the summer and just leave the emersion heater switch on,no timer on it,or should I fit a timer to it?,then the only gas I would be using would be on the hob.
any help advice greatly appreciated,cheers
