Potterton Profile 60e
15 Sep 2009
Kent
Hi. My Boiler fires up ok but after a short time, about 90 seconds, the gas supply appears to cut off leaving what I think is just the pilot light although the pump and the fan remain running. Is there a simple remedy or something more serious. any advice please.
THANKS, Problem solved, traced out fault to dry joint on p c b dab of solder, tested and o k.
So after working on the boiler, has the case seal been tested and the burner gas pressure measured as required for basic safety and to comply with the legal requirements of gas working?
Tony
A professional has difficulty attaching tube to burner pressure test point on these let alone a diy-er. ...:ROFLMAO:
