I have no heat in my radiators, the hot water is okay. The burner was replaced after the boiler kept cutting out. After I replaced it no heat was coming through the radiators. The burner was in a mess when it was replaced.
The boiler fires for about two minutes and then cuts out, the pipes around the boiler are hot but the pipes next to all the radiators are stone cold. I have drained the system, refilled, checked for leaks, air, put in sludge remover, checked all seals on the boiler. Drained the system again and the boiler checked the flow and return pipes for blockage nothing. I have also now ordered a flow switch as I am now thinking that due to the state of the old burner some bits may have blocked it or got into the system. I am increasingly thinking that due to the state of the burner it may have fed into the whole system. Now when the boiler lights there is a lot of pipe noise and wooshing. Have had enough of it now HELP !!
