Hi, just after a bit of advice please. I have the above boiler and it keeps failing to fire until I press the reset button.
About 2 years ago I had TRV's put on all rads apart from the room with the stat installed, whereas before there were 8 rads without. Since then I've had this issue.
I have British Gas homecare and have had them out to look a couple of times, first time the guy said it was because the stat in the boiler was up too high (it was turned right up) so he turned it down as he said it was overheating.
Second time the guy changed loads of parts, but it's still happening intermittently.
Could it be because of the TRV's being fitted that the boiler is overheating, I'm thinking if all the TRV's are satisfied there's not enough in the non satisfied rads to take the heat away from the boiler. If thats the case would turning the internal
stat down some more solve the issue? Anyone with any experience win this boiler know where it should be set to?
Obviously I'm aware that I can get BG out again but just looking for a second opinion really.
