My Suprima 50 is around 8 1/2 years old but has now developed kettling or banging through the pipes just as it reaches its peak heat before shutting off. I have run a descaler through it and bled everything, I also changed both the thermister and overheat stat but the problem is still there. I have tried different pump speeds and have had to turn the boiler temp right down to make the problem more bearable. I now leave the hot water/heating on constant to keep it warm, as the evening goes on the boiler cuts in and out with no drama as the temperature is constant and doesn`t need much heat top up, however have a shower and the boiler cuts in to warm the cylinder the banging is back. I`m no engineer but have done all the plumbing on this system and its been fine for around 8 years, I`m thinking maybe the heat exchanger is restricting the flow and causing the problem.
Sorry to go on, just wanted to state all the facts.
