Potterton Suprima HE 60 Green / Mains Light flashing
29 Nov 2010
Berkshire
I have Potterton Suprima HE 60 boiler and the Green / Mains light is flashing. Is this the sign that the PCB is faulty?
No, flashing green light usually means boiler thermostat knob is turned off?
Reached temperature-or at least it believes so.
Is the boiler not operating correctly?
The boiler wasn't working on Sat so I called BG and the engineer came in on Sun. However, the boiler started working on its own. He said that the flue isn't supported in the loft so they wouldn't cover it. Also, he said that it is possible that on Sat, due to the condensation coming back into the boiler, the ignition switch wasn't working or boiler was thinking there is no demand and it wasn't kicking in. And because the condensation had dried up, it worked on Sun. Also, he said that the fan and secondary heat exchange are noisy which would need replacing.
I need to clamp the flue in the loft to provide support.
