I had installed incandescent puck lights connected via dimmer switches under the kitchen cabinets. They worked well, but they got very hot and burned out frequently. I had 5 40 watt pucks and 2 60 watt larger style pucks. Total power consumption was about 320 watts. I decided that I should go green and install lights that consumed less power so I replaced them with 6 strips of LED lights. The total power consumption of the 6 strips was reported to be 10 watts. There is an inline transformer that cuts the voltage from 120 to 5 volts. I did not replace the dimmers, even though the instructions said that they were not to be used with dimmer switches. After several days/weeks of working perfectly, they started to blink. I assumed that it was the dimmers that were causing the problems so I replaced the dimmers with a standard switch. The problem did not go away, so I then assumed that perhaps I had damaged the inline transformers, so I purchased a new set of fluorescent lights, total wattage was going to be 55, so still an improvement.
I also decided to buy a voltage tester because I messed up the wiring and I couldn't remember what was hot and what was not. I tested the voltage on the main power feed and got a reading of 120 volts, perfect.
I then tested the power from the just tested hot (black) to the black of the supply line to the 1st transformer and it was only 90 volts. I then tested the hot to the black of the 2nd supply line and only got a reading of 60 volts.
Is the voltage drop a sign that I have indeed damaged the inline transformers? or is something else going on here? I am using 14 gauge copper throughout.
