i want to install some equipment in the loft & would just like to confirm what i want to do is allowed / the right way to do it...
the equipment to go in the loft :-
4x 12vdc 1A psu or 1x 12vdc 4a psu (havent decided yet)
240vac 16port network hub,
240vac cctv recorder,
12vdc tv aerial amplifier (global loftbox)
2x flourescent striplights.
I can happily take the lighting from the upstairs ring, i've done it before & enough threads already on here to know what is the right way
However the remaining equipment I believe it is too much to take from a lighting circuit, and am certain the housing association wouldn't let me. (they fight everything they dont like inc a diy'er & electrics)
Would it be okay to take a spur from a double socket on the upstairs ring main into the loft, put it on a fused spur, then create a mini ring from the fused spur? can you get a fused spur with rcd protection rather than having it on every socket?
i would require probably 8 sockets (4 doubles) with a total load of no more than 13amps. I am not sure how to calculate actual load as some of the devices state 1A @ 12vdc, not 1A @ 240vac. i'm not sure if the amp's are the same or if there is some maths needed when converting from elv dc to lv ac...?
Please let me know what you think, the last time i approached the HA with a request like this, they tried to enforce a sparky with a new circuit completely...... (they just don't like tenants playing with the electric, which is understandable)
the CU has been replaced recently, its a volex protector with RCD protection. kitchen sockets on 1 trip, the rest of the house on a 2nd trip. the shed then has its own trip. lights upstairs & downstairs have been seperated with a trip for each ring but not the sockets. (32a trip for the sockets upstairs / downstairs)
thanks
thanks
