In the process or getting a power shower.
Here's the details:
The hot water cylinder is in the airing cupboard, the salamander pump will be on a shelf just above it, the cold water tank is in the loft 2 foot above the pump.
The run from here to the shower is about 20 feet, the 9inch diameter shower rose is 4 inches from the ceiling.
The vents/flanges etc that are needed will be sorted out by a plumber as yet not arranged.
Using a Salamander CT75 pump would this be ok, have heard somewhere that from the bottom of the cold water tank to the shower rose should be 2 feet, if this is the case I would have to raise the tank in the loft and also run the pipework at waist height in the loft!!!
Here's the details:
