Hi guys, I've got another issue hopefully you can help as usual.
I have a triton thermostatic power shower which does nothing when I press the on off switch, no noise or anything. I turned it off at the fuse and took the front case off, first thing I noticed was that the top screw had been sheeted off and when I pulled it off from the bottom a small amount of water poured out (from inside the casing).
I can't see any obvious signs of damage other than the water getting in, any suggestions on next steps?
Thanks guys, apoligise if this should have been put in plumbing
