shower not working
bcx
16 May 2008
Derbyshire
Hi
Having problems with a Triton Rapide 2 shower.
When you turn the power switch on at the shower unit it just makes a 'buzzing' noise and no water comes out. The shower has not worked since moving into the house.
I have checked the electrical supply and there is power to the shower unit and no obvious faults visable inside when I took the case off, any ideas for what to do and what could the faulty part and problem be please?
Many thanks
sounds like you have faulty relay that activates the solenoid valve to let water in.
Thanks for your reply
What does this part look like please? Do you have a link to a picture/diagram if possible?
Cheers
Have at a look at the Triton website :rolleyes:
You should get all the info you need about your shower. You can always phone their technical help
Rapide 2 plus electric
Power neon
The price is £10.15
Thermal cut out
The price is £20.53
Switching module assembly - up to 9.5kW rated units
The price is £21.69
Microswitch and wire assembly
The price is £10.83
Heater can assembly - 8.5kW
The price is £46.61
Heater can assembly - 9.5kW
The price is £46.06
Stabiliser valve assembly - up to 9.5kW rated units
The price is £28.22
Solenoid valve assembly
The price is £31.47
Outlet pipe assembly
The price is £23.79
Pressure relief device
The price is £8.84
Trimplate - white
The price is £10.93
Front cover assembly
The price is £20.37
Pipe trim (backplate/trimplate)
The price is £8.52
Sorry I've visited the site, I've copied and pasted the price list :oops: Is it Switching module assembly that I need please?
If you can't diagnose it with a meter, you'd best call their technical line.
