- Joined
- 27 Jan 2008
- Messages
- 27,689
- Reaction score
- 3,356
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
My parents have had a new central system fitted with a closed system combi boiler rather than the original open vented boiler.
The shower now seems to alternate between hot and cold it warms up as expected then cools down again before getting hot a second time.
It is a power shower and I thought one could not use a power shower with a combi boiler also since it is now connected direct to incoming cold water rather than from the cold water tank it can suck on incoming main I thought this was not allowed?
There is also a lack of any stop cocks other than the one on incoming main I would have expected to be able to isolate the shower as we could before and the hot water supply.
We asked for a programmable thermostat and got a thermostat and programmer and we can’t adjust the hot domestic water temperature independent to central heating water. Should a thermostatic mixing valve have been fitted? Remembering my Mother is in a wheel chair due to losing one leg and is as a result unable to react quickly to over hot water?
Thank you for any replies.
