Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
Hi,when repainting exterior woodwork does anyone use a wood preserver on bare wood that has been exposed during prep work or just primer,I have always just used primer and was wondering if this was right,many thanks
I would often (but not always) use a wood preserver on timber that is exposed to the elements as it does tend to help it last a bit longer. The downside is that you need to let it soak in and dry for supposedly 3-4 days, which is why I sometimes didn't use it. I always found that it would still be a little greasy and gave it all a wipe down with a dry cloth just to remove any excess residue.
Most water/oil based paints can be applied on top of dry preservative.
