- Joined
- 2 Nov 2003
- Messages
- 2
- Reaction score
- 0
- Country
My combi gas boiler was working fine whilst just heating up water - central heating switched off - during the summer.
I have now switch it to both hot water and central heating and it worked ok for a couple of days - but yesterday the pressure dropped and the boiler stopped working.
I aired all the radiators and topped up the pressure using the feed loop up to 1 Bar. and left the boiler in the hot water and central heating option but did not turn on the central heating (switched the timer to off) to see if the pressure would stay. after about a day the pressure had dropped to 2/3 of a bar.
I looked at the Pressure release overflow pipe and it was letting water out (very low flow of about a couple of drops every ten minutes) and the ground below it was wet.
Can you please help me with the following questions:
- Why is the overflow dripping if the pressure is only at 1 bar - could it be that I have a faulty PRV or a faulty expansion vessel?
- In the past I have had a leaking central heating pipe that was repaired so I do not think that it is the Central heating pipes as it was ok after the repair during last winter- If there was a leak in the central heating pipes would the water also escape from the overflow as a symptom?
More info:
The boiler is an ICON 23T about two and half years old.
Thanx in advance for your help.
Sleepy
More info:
Sleepy
