Pressure relief value: finding a replacement
30 Aug 2007
Sussex
I have found that the pressure relief value, on my solar HW, has a very slight weeping. I suspect that that there was some debry left in the system.
Problem now is finding a replacement valve.
The plumbers merchant I use does not have any with a bleed screw. Any ideas as to a make that has a bleed screen so that we order one?
There are no real identification markings.
Either way I am just going to replace the pressure gauge.
Actually thinking about the question it's stupid...
The bleed screw is not needed at all, I can just turn the valve handle.
The question should have been: Can anyone recommend a 'pressure relief valve' manufacturer with a very good MTBF?
Damian
