I've got water dripping through the tundish on my megaflo system. Quite a stream of water is coming out of the overflow pipe.
I've recharged the air gap and still have the issue. The water is cold so is not coming from the pressure relief valve on the cylinder. It continues to drip even if I isolate the water supply, so it appears to be coming from the water inlet pipe at the bottom of the cylinder.
I think I've narrowed it down to the pressure relief valve on the incoming supply...
https://www.unventedcomponentseurop...unit-pressure-relief-manifold-core216000.html
The question is should I get the whole thing replaced or just the cartridge...
https://www.unventedcomponentseurop...2116-pressure-relief-cartridge-zrc214009.html
Is there anything in the whole unit that could have failed or will replacing the cartridge solve the problem in most cases? This whole valve was replaced 3 years ago.
Don't worry, a local plumber certified to do this work will change the kit for me. I won't be taking any chances!
