Pressure testing a wet underfloor heating system
1 Mar 2016
Runcorn
I will run several wet UFH circuits (ground floor to be screeded system and 1st and 2nd floor pro-fix panels and then to be screeded / levelling compound).
Is it best to pressure test these? If so, what pressure does UFH normally operate at, is it between 1 and 2 bars like a boiler?
The above questions are just for my own interest, builders will be doing the work.
What do you mean “then factor in”?
So if the boiler is 1 bar, does that mean my UFH needs no more then one bar pressure?
They will but I want to research before and that’s the point of a discussion forum like this.
But my point is that the value and method to which it is pressure tested will vary according to manufacturer.
For example, Wavin instructs 1 bar for 45 mins; then 6 bar for 15 mins; then 2 bar for 15 mins.
And, as your warranty/guarantee depends on following the MI's, that's exactly what you must do.
The floor heating warehouse (supplier) has provided no such instructions.
