I need to fit a pressure vessel to my heating system and have a couple of questions (prob more)
Is it ok for the discharge pipe from the safety relief valve to exit about a foot up then run down the wall and finish an inch or so from the ground ? or does it have to be up high.
I plan to fit the vessel in the return, but the 22mm pipe is very tight to the wall and will be difficult to cut and get a fitting on. Would fitting it about 6 ins after the pipe reduces to 15mm be ok as it would have a rad pipe between vessel and boiler.
Appreciate any help
Appreciate any help
