As some of you may have read from my last post I'm building a grow box for some tomato plants.
The lights I am using are 150w HPS and will be on for around 6 hours per day. Now I know that if I use propper battons, make tight connections and use correct gauge of wire, fire risk will be minimum, but I'm a bit of a worrier if they are on and I'm out.
Is there anything I can interrupt the line with which will prevent a fire, i.e cut out before it gets too hot. Not sure if an RCD would suffice for this?
