Hello All
I'm a competent DIYer, fitted bathroom/kitchen but never really dealt with the central heating system.
I want to replace a old single cast iron radiator for a new double convector radiator to increase the warmth in the room. So i started to do a little research on my setup.
I have an old system with an ageing potterton kingfisher 2 boiler, a hot water cylinder tank and a single water tank in the loft. After searching the internet looking at systems that didn't quite fit i came across the Primatic CH system which seems to match mine and is likely as system was fitted in the early 80's.
This system works very well and has never given me any problems (10 years!!) so i dont really want to replace this system at the moment even though a newer system would be alot more efficient for the future.
anyway back to my radiator,
Do you need special radiators for Primatic systems as its not recommended to put inhibitor in this type of system?
The old radiator has old fittings so i would need to replace the lockshield valves at each end of the radiator to fit a new modern radiator.
Can you fit a thermostatic valve at one end of the radiator on Primatic systems?
i would need to drain the system to change the valves (unless anyone has any special techniques) i would be very grateful if anyone has anyone got any experience/tips for draining and filling Primatic CH systems?
Dave
Dave
