Hi all,
i'm having trouble with the boiler mentioned in subject. I think it may be a pre 2001 ace.
Problem is when HW is run the boiler starts up fine, runs for about 20 seconds and then the burner will go off, wait for 10 seconds or so and then the burner will come back on and repeats like this.
I read on a another forum that sometimes the heat exchanger can get clogged if its not installed properly so i drained the system and removed it, flushed it out and a fair amount of black crud did come out. replaced the heat exchanger but still had the problem.
I checked that flow switches were working and cleaned them for good measure...still had the problem.
Next I thought it maybe one of the thermistors giving a bad reading, so i thought rather than spending £30 each on 2 thermistors i would buy a couple of 6kohm resistors, to frig the system and identify that the problem was the resistors. (thermistors read 10k at 25 degree, Negative curve)
I thought I had cracked it, with a resistor in the end of the lead for the CH thermistor and plugged in as normal on the HW the boiler seemed to work fine, after a minute or so tripped on overheat, which i was expecting due to giving it a false reading.
So i popped out and bought a thermistor, swapped it over and i still have the problem...
I am now wondering if the burner is not modulating. Is there something in the program that says to turn off the burner at a certain temperature before its reached the temperature for a safety lockout?
I measured the DC voltage going to the modulating gas valve and when the burner starts it rises rapidly to 18v and stays there until the burner goes off. is that normal?
Another thing, I thought i would try swapping the thermistor leads around, so the HW was on the CH tthermistorand so on,
Strangely the burner did not go off, but the hot water was being diverted to the CH and not the HW I cant get my head around that to be honest.
Any help would be greatly appreciated.
Chris
Chris
