Problem with boiler overheat lockout reset Halstead Quattro
17 Nov 2007
Yorkshire
hey,
I've moved into a house recently and been having problems with the boiler (Halstead Quattro).
The heating has been set on the timer and usually works fine.
Occasionally the central heating stops (cold) or comes on but at a low temperature. When this happens there is no sound coming from the boiler, so no indication of boiler burning, etc. Same problem happens with the water, sounds like water flowing through the boiler but no hot water. Especially annoying when i really need a shower, then desperation overcomes me and i usually end up adjusting the dials that control the temperature of heating and water and sometimes switch the boiler off then on at the mains switch. Sometimes it works but i cant really remember as i'm p*ssed off by this time.
The killer problem came this morning, the overheat light (red) came on. The boiler is still on as its making a sound but no hot water or heating. After reading the booklets that came with the boiler and checking on internet forums. I switched the boiler off at mains, to give it time to cool down. After a few hours i switched it back on, the red light remains. I then attempted to press the lockout reset button at the top of the boiler but all i found was a small circular hole and a sticker that says 'set' but no button.
there is no leaking or weird noises when it was working.
Anyone know what the problem is and how to solve?
Probably will have to call someone to come over to have a look. I'm in Huddersfield, west yorkshire. any idea approx how much a call out charge should be. also, even though the problem hasnt been diagnosed how much should this type of job cost.?
any help/advice regarding problems or hiring a plumber(is this the right person) would be appreciated.
Don't know Halsteads intimately, but are you sure the red light is overheat?
I thought this was ignition lock out :?
I had a similar problem i went to on saturday, i believe it to be the venturi's.
However, the screws were wrecked on the fan so couldnt remove it to check. new fan going on tomorrow.
The overheat reset button which should have been accessible from the top of the boiler was broken so it had to be opened up to reset.
