Problem with central heating pump
11 Feb 2010
West Glamorgan
It's a Grundfos central heating pump 15/60. It looks relatively new, although it is at least 8 years old, in that it's clean with no leaks or corrosion. The issue is that its not pumping. I've removed the bleed screw and I'm able to freely rotate it, so it's not jammed and I've used a voltmeter and the electrics seem fine. From reading around it seems that it needs replacing, but before I do is there anything else that I can try? Many thanks
I had the same problem some time ago. There's a start up capacitor inside the connector block housing. It had 'dried out' with the heat. A replacement soon had the pump up and running again.
With the bleed removed and pump s/w on, does the impeller spin?
Thanks for the reply. No it doesn't. Some water and steam comes out. I have thought of taking the pump head off just to see whether there is anything obviously wrong. Would that be a good idea?
If you are a baggies fan I don't know why helping you but here goes! :p
If you have 230 at live, tested across L and E and L and N and spinning it doesn't kick it into life, (proves capacitor is not atvfault) then it does sound like new pump time I'm afraid.
Boing boing
Jon
Boing boing
Jon
Thanks for the advice. Yes there is voltage over both of them. Come on you baggies!
Well I can only hope that your heating fails miserably and you suffer a cold cold winter!
Otherwise it's new pump mate.
I'm villa hence the banter.
Good luck with the heating if you need owt else let us know.
Jon
Just a quick question about which pump to buy. I was going to replace with a Grundfos but noticed that you get a Parker pump for £42 on the link below:
https://www.amazon.co.uk/Parker-Cen...79544229&sr=8-1&keywords=central+heating+pump
I appreciate that Grundfos clearly have a good reputation, but we are hoping to replace our system as its an old fashioned boiler, single pipe system in the next few years. My question is with a new condensing boiler can you use the existing pump? If so I may well pay the extra and get the Grundfos. Many thanks
@baggielad generally the combination boiler will have the pump built into it so the existing pump would be removed if you are converting the system.
Depends on the size of your property, amount of bathrooms and the usage patterns but combinations are only really suitable to small 1 bath properties as they will struggle to cope with two outlets at one time.
If you have decent incoming flow and pressure you could look at an unvented cylinder that will give you mains pressure hot water and a balanced cold supply, keeping the new pump and a heat only condensing boiler.
Jon
