The shower runs off a bath mixer tap. In the mornings, very little cold water comes through the shower head unless you open the cold water tap on the basin and then close it again (this isn't always effective tho! & more often than not the shower water temp is too hot).
Also, sometimes hot water can be drawn through the cold tap on the basin!?
The bathroom is supplied with hot water from a direct cylinder & cold water is supplied via a storage tank. It looks as tho' there's a pump situated at the base of the cylinder cupboard but it doesn't work.
Do you think that replacing the pump/ getting it working again will sort out the problems? Can anyone advise?
