Hi Everyone,
I am currently experiencing problems with my Wickes Aquatronic 1 plus electric shower. To give you some background, my shower is based in a 3rd floor flat and is feed by a cold water tank in loft above. The shower has worked fine since it was fitted in July of this year, but over this last week I have been unable to get hot water from the shower in the morning (7-9). As the shower was in warranty I called the company that made it and was informed that it was probably one of the following reasons that it was not working (I was also informed that if I called an engineer out and it was not a fault with the shower then I would have to pay the engineer £70):
1) I was trying to use the shower in a peak period and the water pressure would not be enough to get the hot element working? Would this be a problem after 4 months of use?
2) I need at least 20 meters of pipe between the tank and shower for the shower to get enough pressure? Once again would this be a problem after 4 months of use?
I see it as I have 2 options:
1) Call out the engineer and face the possibility of paying him £70 becuase the pressure is not great enough and there is not 10 meters of piping between the tank or shower.
2) Fit a motor (£100 +) to find out that it is a fault with the shower.
Any advice that you can offer will be greatly accepted.
Mike
Mike
