In order to build my extension I had to demolish a conservatory. Now that the extension is done, what's left of the conservatory is a 2.5m x 3m slab surrounded by dwarf wall.
I want to tidy this up and reinstate a conservatory, but have noticed that the last six months of rain have caused the 100mm kingspan under the concrete to become waterlogged.
I've not helped matters by paying great attention to DPM detail during the build, meaning that the conservatory DPM was made good, lapped in to the new house DPC/DPM, and has been a water tight swimming pool, in which the slab and kingpan have been bathing all winter.
I've read on other posts that PIR board is non porous and this shouldn't really be possible. What I'm seeing is that when I prod the side of the PIR board with my finger, water oozes out. I've snapped a 50mm edge off to see how far the water has penetrated, and it seems to have travelled well in to the board.
Does this just look worse than it is? can I expect it to dry out eventually? It's foil sided board so I'm not sure if the water will soak back up in to the concrete particularly well.
Gary
Gary
