I have an old Baxi Bermuda back boiler which I service regularly and the system was running fine until last weak when the CH failed (hot water was still OK). The pump was turning but no water flow, so I replaced it. The problem now is that the water is going through to the upstairs radiators.
I bleed the radiators downstairs and they had a bit of air but then water starting coming through. However on the upstairs RAds all I get is a bit of air escaping at first and then nothing no water. I subsequently trained the system from the lowest radiator and found that only a small amount of water came out. Now even the lowest radiator has hardly any water in it.
I am at a loss to figure out why the water is not flowing through the radiator when the CH is switched off (gravity should take care of that). I know that that air is being pushed around the system by the pump, but that's because no water is coming through to it (I checked).
Can anyone please help?
I have replaced the same pump a few years a go and I did not experience any problems like this!
Many thanks in advance
