Programmable thermostat suitable for a Ferroli Optimax HE Plus 31C
8 Jun 2013
Gloucestershire
I have the above boiler. It runs fine and I've just had it fully checked and serviced, but there is no display on the clock. It appears that replacement clocks are no longer available. Can anyone recommend an external programmable thermostat that would suit this boiler?
Somewhere among these pages someone recommended a Honeywell CM7 series one. Is there a cheaper alternative that would suit?
How easy is it to install? Will it be a case of just taking the front off the existing room thermostat (non programmable) and then will it be obvious? ie swap like for like with the wires? Or is it going to be a massively complicated job?
Many thanks in advance.
Rr
you can use any external one and the internal one is still available but they are like the boiler, total shoite
