- Joined
- 20 Feb 2026
- Messages
- 1
- Reaction score
- 0
- Country
Hello everyone,
During a recent refill of our boiler, the internal pressure relief valve (PRV) opened as expected at around 4 bar. However, after the pressure returned to normal operating range, the PRV did not fully reseat. It is currently leaking at a very slow rate (approximately one drop per minute).
So far, there has been no measurable pressure decrease in the system, but a gradual loss of pressure over time is expected. The discharge is routed through a small drain hole and collected in a bucket located under the boiler.
Our next scheduled maintenance is in about 18 months. I would appreciate your advice on the potential impact of leaving the situation as-is until then, specifically:
Thank you in advance for your insights.
Best regards,
- Risk of internal corrosion in the boiler due to periodic makeup water as pressure slowly drops
- Corrosion risk in associated piping from oxygenated fresh water ingress
- Effects of slightly elevated humidity in the boiler vicinity from continuous minor leakage
- Any safety or reliability concerns with a PRV that does not fully seal after actuation
Best regards,
