Pugeot 106 screen washer?
26 Jun 2004
London
The pump motor spins but no water arrives at the windscreen jets.
I assume there is a blockage at the inlet ???
But I cannot see any obvious way to access the motor!
Any ideas?
Tony
The motor is a push fit into the bottom of the plastic washer bottle.
Your problem could be a blocked inlet - obviously - or maybe the pipe leading up to the screen is kinked or blocked.
Usually i pull off the pipe at the bonnet jet, and see if water spurts through.
John :)
Thanks John, but a quick look from the wheel arch and a bit towards the underneath does not seem to be able to see any part of the reservoir.
It seems to be competely boxed in!
Do you know where it can be accessed from?
Tony
Assuming the 106 is the same as the Citroen Saxo, only the filler neck is visible from under the bonnet. The reservoir bottle is beneath the inner wing, so its wheel off and plastic arch liner removed, offside.
John :)
I think the plastic liner is riveted on.
Is that a drill out and pop rivit job?
Tony
