I have practically zero pressure in my hot water supply and am wondering if I can fit a pump to it.
The reason is that I recently had a plumber install a new bathroom and an ensuite shower/bathroom in a flat I own. The original supply was provided through 15mm pipes. What he has fitted are the new smaller pipes in the baths and washhand basins which I assume are 8mm or less. The hot water tank is at head height and the resultant flow is such that it would take hours for a bath to fill. The cold supply is OK as all baths/basins are fed off the mains.
Can I install a pump to increase the hot water pressure? If so, does it go on the flow or return side? I have seen mention of positive and negative flow pumps but have no idea of which side to use. Instinct says the flow side as this must presumably ensure that there is always water in the pump but instinct is not always a good guide.
If a pump can be used can anyone suggest a manufacturer to go for?
Many thnks.
Sisyphus
Many thnks.
Sisyphus
