Pump noise
6 Jan 2005
Recently (just before Christmas) descaled central heating using Fernox DS-40, flushed system out with neutraliser plus three flushes of cold water. Refilled system, added inhibitor (hard water area).
System is working fine now.....EXCEPT:
The pump (Grundfos, three years old, don't have the model number to hand, sorry) constantly makes a "ticking" noise (sounds a bit like loose ball bearings rattling around, though I hope it isn't that!). When the heating switches off the pump makes a sort of "whooshing" sound (like sand running down a pipe). This happens regardless of pump speed.
The system is pretty air free as far as I can see (I've bled it quite a few times, all the rads are hot all the time).
Could this still be sludge in the pump/system? (Shouldn't all the flushing have got rid of it?) Or am I looking at something more serious?
Air sounds just like sand particles. Collecting any air anywhere? Check pipe layout, and joints on input side of pump back to boiler are all A1, as tiny leaks there can let air in.
Whooshing is airy water moving to release pressure/head. What's pipe layout from boiler? Check there's no pump-over in f& e tank when pump starts/stops
NB you did neutralise the DS-40?
