Hi
Am after some advice as to where to start looking for a problem with a central heating system.
It is a S plan system with a Grundfos pump and standard 3 way motorised valve. The pump has suddenly started running constantly and the only way to turn it off is to switch off the mains supply to the boiler circuit. It runs constantly even when the control panel in the kitchen has HW and CH turned to off.
The motorised valve seems to be working ok in that it goes to all 3 positions, could it be a sticky switch in there somewhere? Would this cause the pump to run constantly even with no CH or HW 'programmed' on?
Or could it be faulty programmer?
Any help appreciatted.
