Hi there,
There are a lot of discussions around SW/PF but I just wanted to ask a simple question.
I need to connect a 50mm SW Waste Pipe into a stack ... can I use a push fit boss adaptor on the stack to connect the 50mm into? The reason I wanted to do this is that I am struggling to find the correct Solvent Weld boss adaptor, which makes me think most people just push fit the waste pipe into the stack...
If I am wrong could someone point me to the correct Boss Adaptor for solvent weld. I will probably use Osma...
Thanks in advance.
Will
Thanks in advance.
Will
