putting pipes in wall
5 May 2006
Liverpool
i have 2 water pipes runnining down wall in kitchen and want to put them in the wall do i just use elbow connectors to move then back then refit pipes.and can you put flexi pipe in wall thanks in advance
Why not just use guildflex plastic trunking which hides them quite nicely.
Save yourself a lot of work too.
Cost you about a fiver and take you 10 mins to do.
If you must, you can swop the pipes for plastic. :D
i wish i could but need to move them to put a cooker hood in as they are in way but thanks
Channel out the wall where required, probably with an angle grinder and replace the copper tube like for like. Depending on the age of your house you may find that the timbers behind the plasterboard will need to be notched out so as to allow the siting of the pipes. It will help no end if you can solder.
You can use plastic if you really want to, I wouldn't, not even in my enemies house.
:D  8) :D  8) :D
:D  8) :D  8) :D
so will i have to use 2 elbows to get it into wall as the pipe are coming up 1 elbow to turn it into the wall then a bit of pipe then the other elbow to turn it back up
