Pyronix Enforcer V10 - "Wireless Ch To"
23 May 2018
Pyronix Enforcer V10 - "Wireless Ch To" entry in the Panel log at almost the same time each day for the past two weeks.
From research I think it is seeing some 'jamming' or interference and hopping channels. Is this understanding correct?
Is something wrong with the installation?
Can it interfere with other systems using 868 MHz?
Does it just swap between two channels?
Any equipment that uses 868 MHz can and will affect other equipment using 868 MHz.
All equipment that uses Licence Exempt wireless channels should be designed to cope with transmissions from other equipment that is using the channel correctly. Transmissions should not exceed 1% of the time on 868MHz band Licence Exempt channels
Some rogue equipment does not use the channel correctly and transmits for longer periods than the licence conditions permit. These prolonged transmissions can prevent other legal and compliant systems from operating effectively.
