I’ve had a partial rewire and the electrician removed the old shed socket because the shed was being demolished. The original 2.5 mm² T&E that supplied that socket is still in place from the kitchen to the shed location, and it forms part of an RCD-protected socket circuit at the main consumer unit. Now that the new shed is installed, I want to reinstate a socket by fitting a BG Nexus Storm IP66 13A weatherproof RCD double socket directly onto the end of the existing T&E. I’m not creating a new circuit; I’m simply putting a socket back where one used to be.
Before I go ahead, I’d like a second opinion. Is it acceptable to terminate the T&E directly into the weatherproof socket without adding anything else? Are there any safety or regulatory issues I should be aware of when reinstating the socket on this spur?
I am aware that armoured cable is preferred, but the T&E is already installed underground with a protective sheath and I don't fancy digging up my patio (it's crossig a roughly 2m stretch of patio to the shed). Any advice appreciated.
