Was wondering if it's ok to recyle the water in a system simply by attaching a hose to the last radiator's bleed valve (as I would in a complete drain downl) and opening the bleed valve but without securing the ball valve in the f&e so that the system continues to supply fresh water while flushing out the old cruddy stuff.
If so could there be any added benefit in having the pump running for added pressure?
I only did one drain down after having sentinel x400 in the system for 2 months and whilst fiddling with a radiator today learned that one drain down isn't enough to get clear water (duh!).
I don't really want to do a complete drain down and re bleed my radiators again
