Hi
Just installing a water heater for a boat that's fed from a 3 bar water pump (12v). It's a 30l tank with a 2kw immersion heater in. Fitting a pressure relief valve and expansion vessel but have a couple questions..
do these both go on the cold pipe that feeds the heater tank? I've seen examples of them on the outlet, but always thought they on cold feed?
does it matter which one goes first along the pipework? I was going to do expansion tank first, then relief valve nearest to tank.
Is this the correct way to fit the pressure relief valve? The top pipe will then just drain overboard.
Cheers
Cheers
