Quick Question
20 Nov 2010
Can i run the hot water on my central heating combi boiler system when my central heating system is not pressured up ie drained down? Obviously the central heating will be switch off at this time.
TIA,
depends on the boiler, probably yes.
isolate the heating flow and return and just drain the system. Leave the pressure in the boiler and it should work.
as Dan said, it all depends on the model really.
Im guessing you're making alterations to the system?
