Hi all.
I've searched this mine of information for about an hour, but couldn't quite find the information I'm looking for.
One of my downstairs radiator pipes leaked. Luckily I was at home at the time.
Quite a lot of water was let out. Whilst the water was still running out I stopped the leak by replacing the leaky elbow pipe. Going by the containers which were used to catch the leak, around 4-5 gallons leaked out.
What I don't know is how to refill the CH system. The instruction manual I have only mentions refill instructions for a sealed system.
The boiler is a Range Powermax 155x, which I believe is just over two years old.
Although it only says 155x on the cover panel, I believe it's an OV155xCP because it doesn't have a pressure gauge on the front of the unit, but it does have a digital programmer.
There are two cold water tanks in my loft, a biggun and a little'un.
So hopefully someone can help - does the system automatically refill itself and I just bleed the air from this rad, or do I need to refill manually?
Would I just use water, or some sort of water+inhibitor mix?
Thanks in advance
Andy
Thanks in advance
Andy
