radiant combi cuts out
5 Aug 2006
Yorkshire
after running hot water then turning the tap off after a while the boiler cuts out on overtemp,when you turn the hot water back on before relighting the boiler the water temp is very hot any ideas why?
It sounds as if the primary heat exchanger is scaled up !!!
Tony
