Good morning all,
I've recently installed a towel rad on the CH system but added a 600w element bought from Screwfix.
Last night I went to switch it on and the RCD tripped on the CU. the rad is connected through a timer switch and FCU but the 3 amp fuse doesn't pop in the FCU. I've disconnected the rad and hung in a light and everything works fine so I have no doubt its the element. It's just going to be a pain as I now need to remove the rad!
Is there any way of testing the element either in situ or on a bench when I remove it from the rad? I know you aren't meant to turn them on but I quick switch on to make sure it warms up should be ok, shouldn't it? Or a con check through the element while it's still fitted (but obviously disconnected)
Thanks for you help.
