Firstly, I'm not a plumber so excuse the poor terminology / descriptions
I have an upstairs radiator which over time gradually ceased to heat up.
firstly, I 'poped' the thermostat pin which I have done successfully on other radiators but this didn't solve the problem.
Then I removed the rad and flushed it through, still didn't solve.
Then I was told to disconnect the thermostat from the radiator on the feed in side and open the valve and run it into a bucket with a view to flushing the pipe through a bit. This I did but nothing but a dribble came through.
Taking a deep breath I disconnected the valve from the pipe which i believe should have resulted in me getting soaked and upsetting the wife as the system was on but again nothing came out.
my questions:
As every other radiator is working fine am I right in thinking I have a blockage in the 'feed in' pipe somewhere close to this radiator. (can't comment on the piping system / layout in use other than its a horrible 8mm bore)
If you are in agreement its probably a blocked pipe I was going to drop some flushy stuff into the system, follow instructions and see if that clears it.... but....
Is it worth when I actually come to manually flushing it, if its still blocked to drop a hose onto the 'feed in' pipe where it would have connected to the rad and push some water back up the pipe to hopefully clear the blockage- or would this potentially cause me more problems than it would solve.
plus... if this is an option, providing I have the drain tape open downstairs, will the water I send into the system find its way out there or should I strategically place the wife in the loft at the same time watching the header tank so she could scream at me as it fills up (basically not sure where the water goes that I would send into the system, out the drain valve downstairs or headertank)
Or does anyone else have a plan B which doesn't involve having it professionally flushed as thats my plan C
all I can say about the system is that I have gloworm boiler downstairs and a hot water tank up in the loft (told you I was technical)
Any suggestions / advice appreciated - Thanks in anticipation
my questions:
