Radiator problem
18 Sep 2006
Yorkshire
some of my radiators are cold to touch at the bottom but hot from the middle up, any solutions ??
Is it an old system, probably sludge, need a flush.
Have you bleed any air out.
'Im not a plumber'
If you are up to it, you could remove offending radiator by isolating the valves. Take the radiator outside, and run a garden hose full blast, both ways to shift the sludge.
The water could be very black, so heavily protect your carpets.
Some rad valves are of thermostatic type and have a frost protection, which means they will open even though you have turned them down to min.
Andy.
