Hope someone can help.
I have recently moved into a new house, it's 15 years old and has a new boiler, but still the original radiators.
Since I moved in I have found that all but 1 radiator in the house are not heating up properly. They are all warm at the top but cold at the bottom. After doing some research many people were saying that this is normally caused by sludge. So I got a plumber out to do a powerflush, however before he started he said that wasn't the problem and didn't do it.
What he said was the problem was that the flow has been plumbed to one of the bottom corners of the radiators and the return is plumbed to the top, so he says that the water is coming in the bottom rushing to the top and going straight out and this is why the radiator is cold at the bottom. All the radiators in the house are like this, apart from the 1 radiator that is working fine which is plumbed both pipes to the bottom.
His advise was to adjust the plumbing at each radiator to bring the return from the top to the bottom, so that the flow and return are both at the bottom.
Can someone tell me if this would cause a problem with the return going out at the top. The evidence is there seen that the 1 working radiator is both plumbed to the bottom, but the house is 15 years only with 2 previous owners so find it strange that the people before had these problems for so long, and didn't do anything about it.
Also don't want the hassle of this extra pipe only to find it makes no difference.
Thanks for any help
Thanks for any help
